Comp is melting down!!! Need help/opinions
So last night i finally got 1600 memory speed stable at 4ghz and i even ran prime for 7 hours w/ 0 errors. Great!
But today I recieved some high speed 3000+rpm DELTA 120mmx25mm fans. So I decided to test them out on my rad. I plugged them all into my case fan controller and turned on the computer. Everything was working just fine.
That is until I started messing w/ the fan speeds. I was looking for a good noise to cfm ratio so I kept increasing the voltage and dropping the voltage. But all of a sudden the comp BSODS. So I thought that was a little odd considering it was stable last night and it was idle here. So I thought nothing of it and decided to reboot. But then things started getting worse and worse. With each reboot windows would hang in different places until finally it started hanging in BIOS. And Finally the system no longer posts !!!
I thought it might have been due to some metal particles that fell onto the board from the fan screws causing it to short so I blew it off with air duster. I even removed the entire board and tried again. But it doesn't help.
I've also tried a different psu and the same errors problems occur. At one point in time even the power LED to the switch wasn't turning on but the system was running. I've also tried using onboard gpu as opposed to my 8800gt. Tried removing and testing each memory stick. I'm out of ideas...
WHAT DID THOSE FANS DO TO MY COMP! SDKFJLASKDFJ ><
Someone wanna help me out here?
System specs:
AMD X2 555be
ASUS m4a785td-v evo
OCZ AMD black edition 2x2gb
Enermax EG465p-ve psu
8800gt
Reset the cmos and try w/out deltas. If it doesnt work, trial and error is ur best bet.
I had one of those Delta fans not long ago, the 4700rpm ones. I swear those things sounded like a leaf blower.
just one more thing b4 bed. it posted ok and i lowered everything to stock and i even got to play bad company 2 for about an hour. however after playing it I touched the Northbridge and noticed that it was surprisingly hot. like it burned my hand hot. This might explain why the comp is so unstable. Anyone know if something shorts do the components get super hot? i still have no clue what could be shorting the board if it is.
All i know is typically the NB is never hot. And the auto setting keeps it at 1.1v. And i've had it up to 1.4v b4 and it was barely warm. So somethings up.
out of curiosity what nvidia drivers are you running?
and no the chipset and heatsink should not be hot to the touch(luke warm maybe).. the AMD chipsets run cool but even then if the heatsinks warm/hot it means its working and doing its job to cool the chipset down.. try running speedfan or everest or HWmonitor and find the chipset temp sensor and see what its showing..
i'm not running the newest nvidia drivers that kill cards if you're wondering. i think i'm using 196.21 (off the top of my head)
My mobo doesn't even have a temp sensor on the NB so i can't check. it only has a mobo temp sensor which makes no sense... reading case ambients?!
