Comp is Cockeyed
Hey guys, what's up? (Retorical)
Anyways, for a week or so, my computer's been a little, cockeyed. To the point where it feels like I'm in a hallway when I use my Comp.
First, lemme say my comp specs:
P4
512 MB + 256 MB (Don't feel like adding) RAM, DDR
2.3 GHz
GeForce FX 5200 126 MB DDR, I think. (Pretty sure)
Windows XP (Home)
Ok, now my problem.
My comp has been runnin' pretty slow, I don't know if it's a problem with RAM or video card.
But whenever I try to reboot my comp, or close a folder window, it goes to a blue screen with a "***STOP" Message, there's two or three that come up at leasure. It also does this when my comp is on to long.
I've already took one ram chip out, then tried it. Then put it in, and took the other one out, and tried that as well.
Then I took both out and put them back in. No use.
Anyone have any ideas? 'cause it got me and my brother stumped...
...what?
Anyway, run CCLeaner, clear out temp folders, maybe defrag. Definitely scan for spyware and virii, etc.
My computer crashes on occasion due to my video card drivers. I don't know why though, but check my sig and that should tell you why I don't really care. Someday I'll upgrade and make sure my drivers are behaving.
