Comp for a client
arabdon1203
Antec LifeStyle ARIA Silver/Deep blue Aluminum MicroATX Desktop Computer Case 300Watt SmartPower Active PFC Power Supply - Retail
ASUS A8N-VM Socket 939 NVIDIA GeForce 6100 Micro ATX AMD Motherboard - Retail
AMD Athlon 64 X2 3800+ 1GHz FSB Socket 939 Dual Core Processor Model ADA3800BVBOX - Retail
A-DATA Vitesta 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model ADBGC1A16K - Retail
Maxtor DiamondMax 10 6L200S0 200GB 7200 RPM Serial ATA150 Hard Drive - OEM
LITE-ON Black ATAPI / E-IDE DVD Burner Model SHM-160P6S - Retail
LITE-ON SK-1688A/B Black PS/2 Wired Standard Keyboard - Retail
Logitech UltraX 931157-0403 2-Tone 4 Buttons 1x Wheel USB + PS/2 Optical Mouse - OEM
Suggestions?
What exactly is your client going to be doing with the pc? How much are you looking to spend on the pc?
That info will help us to make good recommendations.
What are the design goals, and what are the customer's requirements?
arabdon1203 said:
Im trying to spend under $900
heheh, I run away FAST from customers whose only business requirement is a $$$ unless it's an unlimited budget.
- JT
