Bio-Hazard
- Jun 8, 2004
I posted some pics up in the gallery the other day, but thought I post some here to see what comments and suggestions I could get from all the pros here. This is only my second water cooling system I've had, the first being a Corsair Hydrocool...............
I built the system external because there wasn't alot of room inside the case for what I wanted and still beable to work on it easily, as I've got a bit of nerve damage in my hands from the first gulf war...............
Anyway, this is what I installed:
DD D4 12v pump
77 bonnavile dual heater core
Home made shroud (1 inch)
2 Panaflo 120 mm M fans
DD dual 5 1/4 bay rez
Colder high flow quick disconnects
Clear Flex tubing 1/2 x 3/4
Polarflo CPU and GPU water blocks (works better)
Swiftech CPU block
You can read about the complete build here:
Water Box Build.
DD D4 12v pump
Swiftech CPU block
Water Box Build.
