Browsing, Light gaming, Lots of image editing and creating (CS4)
600-700 including tax
3) Where do you live?
Toronto, ON
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
All of the essentials, see below.
none.
6) Will you be overclocking?
Nope
Im thinking two 19" LCDs
As soon as possible
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing special, do you recommend anything extra?
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 7 RC
This is my first build. I chose to buy some parts locally and some online. My gaming wont be very intense at all on this computer. This is basically just for school, work, basic usage, a little gaming and to look awesome on my desk. Here she is:
Case ~ $45.00
LOGISYS Area 51 CS51WBK Mid Tower
Mother Board ~ $150.00
Asus M4A78T-E
CPU ~ $110.00
AMD Athlon II X2 250
Graphics Card ~ $90.00
HIS Hightech H467QT512P Radeon HD 4670
RAM $80.00
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM
For the Optical drive and Hard drive, they're not quite as important, so I'll decide later, probably in the store.
Any comments or criticism for improvements would be great. Nothing has been purchased yet. I am willing to spend up to another hundred if I must.
Thanks so much in advance guys.
-Sdb93
Toronto, ON
none.
Nope
As soon as possible
Windows 7 RC
Case ~ $45.00
Asus M4A78T-E
CPU ~ $110.00
RAM $80.00
-Sdb93
