Comments On Upcoming Build?
Mujuro
Any comments on my new system build? I am on a $1200 budget, I plan on overclocking both the CPU and GPU, and I am a heavy gamer.
Case - $99.00
Lian Li PC-61 USB Black Aluminum ATX Mid Tower Computer Case
Model: PC-61 USB
Power Supply - $124.00
OCZ OCZ520ADJ ATX 520W Power Supply
Model: OCZ520ADJ
Motherboard - $194.00
DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard
Model: LANPARTY nF4 SLI-DR
Processor - $190.00
AMD Athlon 64 3200+ Venice Integrated into Chip FSB 512KB L2 Cache Socket 939 Processor
Model: ADA3200BPBOX
Memory - $121.95
OCZ Gold Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Dual Channel Kit System Memory
Model: OCZ4001024ELDCGE-K
CD-ROM/DVD-ROM Burner - $49.99
LITE-ON Black IDE DVD Burner
Model: SOHW-1693S Black
Floppy Drive - $10.00
SONY Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP
Model: MPF920 Black
Hard Drive - $87.00
Seagate Barracuda 7200.7 SATA NCQ 160GB 7200 RPM 8M Cache Serial ATA150 Hard Drive
Model: ST3160827AS
Video Card - $295.00
ATI 100-435500 Radeon X800XL 256MB 256-bit GDDR3 PCI Express x16 Video Card
Model: 100-435500
ATI and SLI don't mix... if you're planning on using two video cards, then I would swap the X800XL for a 6800GT. Also, if you could squeeze in a little more cash, you should try to get a 200GB drive -- you might be able to find one for around $100.
Other than that, nice job.
yub, either get a non-sli board or get a card that supports SLI if you plan on doing that in the future.
