Greetings fellow VMers. I wanted to see if I could pick your experience and comment on our soon to be setup as well as enlighten me on a few items.
We are going to migrate many of our servers into VMs and we are currently leaning towards the following
2 x Intel® Xeon® E5-2690 2.90GHz, 20M Cache
192GB MT/s RDIMM RAM
2 x 146GB 15K SAS 6Gbps in RAID 1 config (just for ESXi hosts, .iso and template storage)
2 x 2x10Gb DA/SFP+ + 2x1Gb BT Network Daughter Card (4 x 10Gb and 4 x 1Gb)
Additional 1GB NIC's for
Redundant power supplies etc
For the SAN we are planning on:
12 x 900GB 10K SAS in RAID 6 (can't do 10) for 9TB usable
1 x 2x10Gb DA/SFP+ + 2x1Gb BT Network Daughter Card
VMware Standard Accel Kit
We'd like to use the HA and Fault Tolerance so we'll order two of the servers. The host will run 9-10Vm's, all 2008 Server R2 Datacenter. Nothing super fancy on the guest side, PDC, BDC, 1 Exchange (50 users), 1 SQL, Print, other 3rd party, Terminal Server.
1) First question: thoughts about the setup, CPU's, Memory, etc. Should be a beast for 10VM's but would like to hear your thoughts.
2) My second question has to do with the connectivity between the ESX hosts and the SAN. I am getting different information on this so I'd like to hear your input. We will be using SFP+ and I don't see why I can't cable directly from the hosts to the SAN like so:
granted the failover lines (blue) will be on secondary cards but I didn't draw it that way, so imagine the blue lines as a second physical card.
I'd have a 10Gb for the SAN, a 10Gb for the management network and additional cards not depicted here for the guests/LAN. Is there a reason other than expandability I can't do this instead of using an overly expensive 10Gb switch? Is this segmented enough? I'd think the vSwitches would handle that. Seems to me if I added a physical switch, it woud bring in an additional single point of failure so then I'd want two. I'd much rather spend that $20K or so on making the SAN redundant.
That leads to question 3
3) the SAN is really a NAS, 2008 Sotrage Server R2. I'm not so happy about the SPoF with having just 1 NAS so what would be a good way to fault tolerant the storage array? I'd have the funds to duplicate the NAS but what's needed on the VMware side? I'd like to have as close to 0 downtime hardware/VM as possible (excluding software issues)
Thanks your your time and experienced input!
