Comment on my WC Build
Sufu
This is gonna be my second time around building a WCing rig. I am going to be using a 3x 120MM rad, with MB block, mosfet, CPU and GPU with 3x Scythe S-Flex G fans on an Aquaero 4. This is all going to be going in on a Corsair 800D case with a EVGA Classified3 770 board, but don't know if a single Aquastream XT is enough.
I am planing the loop to go Res -> Pump -> Rad -> Mosfet -> CPU -> MB -> GPU -> Res
These I own:
1x Black Ice SR1 360 rad (bought)
10ft of Primochill 1/2" ID 3/4" OD tubing (bought)
Aquacomputer Aquagfx for 8800GTS (previously owned, now going to be for Physx)
Aquaero 4 LCD (previously owned)
Core i7 920 D0 stepping (own)
6GB G.Skill DDR3-1600 (own)
These I am planing in buying:
EK-Multioption RES X2 250ML Advanced
Heatkiller v3.0 Ni-BL for 1366 with backplate
Bitspower Black Freezer MB block
Bitspower Black Freezer Mosfet block
Aquacomputer Aquastream XT USB 12v Pump
1x IandH silver KillCoil
4x Bitspower G1/4 1/2" ID 3/4" OD 45 Degree compression fittings
7x Bitspower G1/4 1/2" ID 3/4" OD compression fittings
tangoseal
Scrap.the physx card and retire the concept. (not to sound mean but it really isnt useful these days, just more heat and electricity honestly)
What gpu and block r u planning?
Sufu
I have 2x 6970 but don't really plan in WCing them. I think it's too expensive and too much heat. 8800GTS i've had for a long time.
