Commando: need watercoolers for mosfets?
Uluquai
Hi,
Currently I have the Asus standard fan on the heatpipe.
The case is open now, but I'm worried that mosfet or even NB/SB temperatures could get too high when I close it.
There are only two slow 120mm fans in this case and I can't add more.
Do you think I'll need to buy extra watercoolers for the mosfets?
Running an E6600 @1,55VCore @3,8GHZ.
Thnx for your opinions :)
At 1.55 volts I’d be a lot more worried about my CPU temps then my MOSFET temps. After the CPU worry about the NB as that seems to be the second hottest component on most of the mother boards these days.
With an over clock that high my first consideration would be a very high airflow case because this new stuff really does tend to run very warm, if not outright hot.
Many of the new cases are trending toward 3 and 4 120mm fans for just this reason. To some degree the case was always a component but now it has become a major factor.
Just my thoughts.:)
Hmm cpu temps are still ok, even TAT won't push them higher than 72°, normal load during 3d gaming ~56°, but I'll go down to 3,7GHZ@1,46V to ensure I don't stress my hardware too much.
So with these settings (412Mhz FSB), do you think I'll need watercoolers for my board if airflow in my case is low?
I'd really like to know this, too. I have the Commando as well, and am near desperately looking for mosfet cooling for this board.
Odd enough as it is, ASUS hasn't even bothered to mount a heatsink over the second set of mosfets (to the right of the cpu). I mean, what's the point of just cooling one set??
did you guy's know that those heat pipe coolers on the asus boards are not copper but anodized aluminum
Nope, didn't know that. But that's pretty f-ed up. Oh well, it's coming off anyway. I'm thinking of placing two Thermalright HR-09U/HR-09S sinks. And then add 2 Thermaltake Extreme Spirit II Coolers, one for the Northbridge, and one for the Southbridge as well. Or go the watercooling route. I'm still undecided.
