Command Prompt commands do not work! *XP PRO*
INFERNO2K
As you can see this is my new problem
I can only run commands like these if I go into
C:\Windows\System32\
How can I resolve this problem.
perhaps your path variable got screwed up? i dont suppose typing 'set path' works?
you can also check/set the path by rt click my computer->properties->advanced->environmental variables and look at path. mine for example is `%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;c:\bin;"C:\Program Files\Symantec\Norton Ghost 2003\"`
That solved it quickly thanks.
My path was corrupt, dont know how it resolved to that.
