Command Line Tags
coastertux
For my F@H setup, I use -advmethods -forcesse when I run F@H. What do these do (I run AMD) and would it be benificial to add or remove any of these?
I would remove the -advmethods tag and keep the -forceSSE one.
Since the points for Tinkers have been recalculated I have been getting upto 4 points per hour per ghz from some of them.
Tinker p694. Points 236. Time 33.66 Hours. 3.5 PPHPG.
Gromac p212. Points 135. Time 33.5 Hours. 2.01 PPHPG.
So with AMD systems Tinkers are now better.
So by removeing the -advmethods tag you will get more Tinkers.
But keeping the -forceSSE one means that in you do get a Gromac it runs useing SSE all the time.
Luck........ :D
Any other comments? I see lots of Gromacs and DGromacs that have high points too.
