Hey,
I'm looking to make a quick set of switches to turn internal sata hdd's on and off.
Now this website: http://www.adpmods.com/case-modding/...les-sp-26.html says the red is 5v and yellow is 12v. Which one do I need to hook up to a switch? 5v? 12v? or both? I plan to mount something that will look like a fan controller in a 5.25" bay that will turn on hdd's individually. Would routing the psu molex end into a protoboard and then routing the power wires into the switch work well? Or are there other suggestions?
Thanks
Guys over at PSU section said to look into Spin-Down...
Thanks
