No status update. Work at gamestop and had to deal with the MW2 launch/anticipation the past few days. Gotta get caught up with school work because Im going hunting on friday>next tuesday. Ill see what I can do.
@Yeold.... thank you so much. You guessed it with DDWRT. Specifically my v24-sp1 build date 7/27/08.
Updated to beta build on 10/10/09 - auto configured the static IP setup on the router interface. I guess in the static IP on the router, it wasnt asking for my external IP(173.xxx.xx.xx) but rather my internal IP given out by my gateway.
I'm not sure on what're saying about the WAN setup of your DD router...are you saying you have it set to "obtain auto" now? Or you still have the static IP info plugged in, similar to what we have in your screenshots.
Sorry, I just got back from hunting, stayed a little longer than expected.
So I think I'm done trying to mess with gateway into router. It was working just fine for browsing the internet, but there were 4 key problems:
1) outlook 2007 wouldnt sent(saying port was blocked?) - but outlook 2010 beta gives a different error.
2)Say for example MW2(PC) - Closed nat behind gateway/router. I tried setting gaming pc as the DMZ, which I was given an open nat.... but I still had connection issues and timing out. Then I tried opening ports 1-62555(or whatever the max is), same issue.
3)I think I'm just unable to correctly port forward behind this combo. Say utorrent. All the ports are forwarded correctly, still with no incoming connections. If I connect my WHS box up to the gateway directly, boom I have instant 2mb/s down and 350kb/s up.
4) lastly has to do again with the WHS. behind the router when I try to connect to my WHS(xxxxxx.homeserver.) I get a login page to my SMC gateway. Even from school I was logged into my SMC, but couldnt get redirected to my WHS.
I think I'm going to give up on it right now. I just dont have the time to be farting around with different settings or different routers. Im going to get the wireless setup correctly(I hope) and be done with it. Maybe in the future there might be a modem I can replace the SMC with. Something like the surfboard.
YeOld - if you have any more info, please dont hold back
-Michael
If you want to dork around with a remote session sometime...lemme know. Although to be honest with you, based on the screenies above, and the info you PM'd me...it all looks correct. I'm suspecting something odd with DD-WRT, some conflict. Actually, PM me your e-mail address..and I'll zip up some screenies I took of one of my setups. SHows a few more settings in the SMC.
