scottatwittenberg
- Apr 10, 2002
ok.. so we have comcast internet..
it will run non-stop for days, but once i get a few torrents going it craps out..
i had a dl-604 router.. and then about a week ago i switched to a hawking hwr54g wireless router... the wireless router was staying connected better.. but i killed it by running 4 torrents at once..
now, with the old router, the cable modem would jsut disconnect.. it would go down to 1 flashing light.. with this one, everything appeared to be working.. the modem will have 5 flashing lights just like everything is working, but it won't connect..
i unplugged both the router and modem twice.. let them reconnect.. and it wouldn't work.. so i went to teh computer with the torrents, paused the torrents.. then uplugged the router and modem and it worked right away after plugging them back in..
so, what do you think the deal is? is seems like comcast has something that just cuts my connection, especially since the modem appeared to be connected.. or can home-grade routers just not handle that much?
its not fun to have to run up and down the stairs to plug and unplug the modem and router to get reconnected..
also,... its and RCA cable modem, what is the ip to get nito it? i used to know and odn't anymore.. i can't reset it remotely anyways though.. i remember that..
