Feb 27, 2009 #1 F Fiala06 n00b Joined Jun 1, 2008 Messages 38 I am looking for a free simple way to combine 2 .avi files. (movies) Any recommendations? Thanks Cory
Feb 27, 2009 #3 S Snowknight26 Supreme [H]ardness Joined May 8, 2005 Messages 4,435 VirutalDub might help if they're the same format (not just extension as all that tells you is the container) and the format allows combining like that.
Feb 27, 2009 #5 Ihaveworms Ukfay Ancerkay Joined Jul 25, 2006 Messages 4,630 Avisynth may allows this in combination with another encoding piece of software.
Feb 27, 2009 #6 F fromeo85 Guest Joined Mar 8, 2008 Messages 2,364 Vermillion said: Virtual Dub FTW Click to expand... +1
Mar 2, 2009 #7 D drdeutsch 2[H]4U Joined Sep 17, 2004 Messages 3,775 I used to use Virtualdub, but it is old and doesn't work on Win 7. I now use Avidemux, which I find works much better than virtualdub. It's got a bit friendlier interface and it makes joining .AVI files much easier. AVIDemux FTW.
