okay i am using a ricochet modem in southern San Diego, and it connects to the network at 460.8kbps. Now my max com port speed is 115kbps, is there a way to tweak it so it can go higher?
Ricochet was a broadband wireless service that went under a while back, so Who are you connecting to? Richchet modems were not comm port based, they were PCMCIA/PCI, so max comm speed is irrelevant. Please fill in the gaps here, if your using a regular dial up modem made by a company that has nothing to do with the richochet broadband wireless service your mis reporting you connection speed.
It's a ricochet modem.. it's not a phone line modem, it's wireless. In theory they are offering/planning to offer high speed service over it. however, you can't put the serial port over 115, so if some genius put 512k service on the other end of it.. well they are an idiot.
The original modems were about 28.8 equivalent, and the serial connection was perfectly reasonable.
http://www.ricochet.net/
Interesting... When this company when under a lot of the users tried to buy it out (service was VERY usefull when it was available, you think crackberries are bad...) but failed. It looks like they found a buyer, a lot later...
What types of modems are available?
Ricochet has external and internal PC Card modems. They use standard serial, USB and PC Card (PCMCIA) communications interfaces. Ricochet modems are portable, compact and rugged and are easy to install and use. They connect with a desktop, laptop or PDA.
It does look like serial modems are available, but I would want to know why when their connect speeds are supposed to be faster than the throughput of the port.
RICOCHET COMPLETE HIGH-SPEED INTERNET, $27.99 per month*
Internet access; no per minute charges
Speeds 4-6 times faster than dial up in all Ricochet coverage areas
Customer service (8AM - 9PM Mountain time Monday-Friday)
Full Service Package with e-mail, web mail, web space, and national dial-up access service
4-6 times dialup is way over 115kbps. Of course they are not listing the actual connect speeds...
