- Jul 16, 2005
I am currently running Windows XP SP2 and running an Athlon64 3000+, Abit KV8-Pro, 512 Corsair.
I am trying to run an M-Pad (the device used to scroll orders in McD's and various other restaurants) and it connects through a serial port.
My problem started by not communicating with the device so I tried safe mode, so no drivers or anything unwanted would take over the COM1 port, no luck...
I restarted my computer into regular mode and now Windows and tried again, no luck, this is the error I receive
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\State Diner>mode com1
Device COM1 is not currently available.
How do I find out what may be using the port?
I checked under device manager and it says the device is working properly and there are no conflicts.
I have tried MODE and COPY CON:COM1: under the DOS window and they I get the above error when useing MODE but when I use COPY CON:COM1: type in some text, then CTRL Z from it, it says information was sent.
I also have setup a Posflex Jiva 5815 Point-Of-Sale machine which I tried hooking a Epson TM-U220 serial printer to and I had many problems there and hopefully someone can help me figure out, does Windows XP have a problem with using COM ports? I am sure if I can figure one out I can get them both working. Someone please help.
I am sorry if the above provided information seems broken up but I am trying to write this before I have to go back to work.
