Meet Colossus:
I named the project Colossus for a couple reasons. #1, Colossus was the name of the first programmable digital computer (reference ) and this is my first 'mod'. Also, Colossus was the name of the infamous computer in the 70's sci-fi movie of the same name (reference) that in conjunction with it's Soviet counterpart takes over humanity.
The cheap flash photo really doesn't do it justice, the flash seems to bring out the minor haze in the lexan that is not visible under normal lighting; it look much more polished and shiny by eye. Don't know why, I just like the 'tech' look of the exposed components.
95% complete, I am finishing a lexan panel that holds the power button and indicator lights (which will be neon) that will be positioned at the bootom right corner.
Colossus started life as a Dell 400Sc server [H]ot deal, picked up a p4 3.2 system for about $200 after coupons and rebates. I built a 1" square tube aluminum frame and mounted the components on a sheet of lexan. Open mounted th psu and hand wired all the components. Chopped off all the drive molex connections, just soildered the plug pins to the end of the wire and heat shrinked the connection to avoid potential shorting.
I picked up a Betabrite scrolling sign display for cheap off eBay. The Betabrite units are nice in that unlike many of the other scrolling displays, there is open published programming data available (many others are propietary). The display connects via RS232 serial and is driven by a small VB app that I coded. This interfaces with MotherBoardMonitor to display all kinds of system stats such as voltages, temps, etc.
Here's a shaky small digicam wmv showing the scrolling display in action. Sorry for the ppor quality, combination of cheap camera and limited bandwidth.
I have been experimenting with coding voice recoginition and speech synthesis into the system, future plans are to see if I can get good voice control and feedback, as well as a faux AI chatbot like WinAlice.
Thanks for looking.
Thanks for looking.
