Colored tubing?
87IROC Z
Anyone know where to get some colored tubing for a watercooling setup? Preferably blue and red solid colored. Not UV tubing if possible. I need it for a mod idea im working on. Thanks! :cool:
Danger Den sells their own brand of UV tubing but it goes for $2.25 a foot, check it out, hope it's what you're looking for.
Thanks, im really trying to look for non-UV though. I need it in blue and red.
you arnt going to use blue tubing for all the "cool" water and red tubing for all the warmer water are you?
That's not tubing. It's for putting on your tubing so it doesn't kink.
Yeah, i need flexible tubing, not pvc pipe. But thanks for looking. So far ive asked around locally and no one really seems to know yet. :(
not a bad idea. anyone ever tried it on flexible tubing before? I wonder how that would hold up.
Vinyl "dye" really is just special paint, so I'd have my doubts about it holding onto flexible tubing.
