Colored Plexi
Novensu
Does anyone know of a place online to order colored Plexi? I am specifically looking for blue.
Thanks,
Novensu
I'm actually looking for some blood red stuff. Living in the middle of nowhere, there is no one that carries colored plexi.
first you can tint the plexi with the same material use to tint glass...
second... i've never tried this, but you can make a glass/ plexi look coloured by painting the sides with the colour you wanted.. this will tint the light entering the glass or plexi making it look coloured.. spectacles lense use this technique to get some minor tint in the lense
you could pick up some transparent red paint from a hobby shop and spray away.
