Color Scheme Question
TehYoyo
Hey all. First post here, so bear with me :) (although I am a long-time forumer)
I have two questions:
1. I'm thinking up my color scheme with a water cool loop and case and fan LEDs and LED kits, etc. I based my system color scheme on Black (case), White, and light blue/blue. I know that in graphic design these colors would look sweet, but I don't know about computers. Most systems I see are a neutral color (black/white) and an accent color (green, red, blue, etc.) At this point in time, I'm thinking:
  • NZXT Phantom Full Tower Black
  • White LED Intake Fans (Side panel - 200mm and dual 120mm, front intake)
  • Blue LED Outtake Fans (Rear fan and dual 200mm on the ceiling)
  • Blue NZXT sleeved LED kit
I will also have a liquid cooling loop which is where my biggest problem comes in play - the cooling liquid. All of my other parts are fairly monotonous - mostly black parts. I'd like my liquid to be Mayhem's White Pastel UV Neon Blue, meaning white under normal light and neon blue under UV. To match that, I was going to sleeve all my cables in white and my power 24-pin as 3/4 white and 1/4 blue.
What do you guys think about that? Do you think there are too many colors?
I'm also considering going black and gold with white LED fans just for normal light.
