I am on my second 2490 because the first one i got had a color shift diagonally across the screen - the majority of the screen is fine but as you go down from the top left to bottom right, there is a yellowish cast. NEC immediately sent me a new one after i called to let them know about this. The 2nd monitor has the same exact issue.
wondering if anyone else has had this problem, or any other inconsistent color issues?
FYI - i sat on with tech support and ran through Color Comp, other settings, etc. Color Comp semi-fixed the issue but limits the brightness so much that i can't get a white even with it all the way up. sort of a washed out grayish tone with Color Comp on.
this monitor costs too much to color shift across the screen. thanks for any info.
