color changing LED's
JR_Rider
on this fan controller....http://www.frozencpu.com/cgi-bin/frozencpu/bus-11.html ...........the LED's change from red to blue is there any way i could just make the leds change from white to blue cause i have a silver case with 6 white led fans and a vantec nexus fan controller where i modded it and put white led's in it instead of blue ......so is this possible
Ya, just buy 5mm white blue dual color LED's to replace the stock ones and there you go.
