Colocated XenServer with single IP
wizdum
I'm looking for guidance on a potential Xenserver setup. I have a fairly beefy webserver that is currently hosted in a colo with a single public IP address. I'd like to install Xenserver on it, virtualize the webserver part, and set up a couple other VMs on it. Is this even possible without external hardware? I imagine I would need to set up some kind of virtual router to make it work. Is it even safe to have a publicly route-able XenServer management interface?
You can have untangle or pfSense as a virtual router. I would shy away from having the management ports open to the world. Maybe a vpn connection in to a machine behind the firewall to manage the VM's?
Thats what I was thinking. Something that would let me give all the VMs a private address, that is routed to the public address. I may be able to convince them to let me put a Ubiquiti Edgerouter (just because i'm familiar with them and the ER-Lite has a pretty small footprint) in front of it if I can't get a virtual solution. I imagine this would be the "normal" setup for a public VM host? As it sits now, my box is in the DMZ, so the only firewall I have is the linux software firewall.
The way we have ours set up right now is our network connection comes in to a physical pfsense box then out to our vm servers. I have a ipsec vpn tunnel back to the office for management and access for the users in the office. The public ip's are firewalled so only port 80/443 are open to the outside.
