Hi all,
I've been getting issues with cold booting. I need to cycle power several times before a post. Once posted the system is solid and even if I manage to get a little OC on to stay it is still solid - Prime95 for a few hours no probs, temps also okay.
It all began when I put a Q6600 into my system instead of an E6600. Saying that I could only get the E6600 to about 3Ghz before would not boot. I am pretty convinced the mobo is the root cause as I tried with different RAM and while not tried the CPU in a different mobo thinking it would either work or not. BIOS are the latest and I also flashed them once more after the installing the Q6600.
Also I sometimes get choppiness in all games without apparent reason and also sometimes the OS itself becomes very slow with the cursor jiterring when moved and all the menus.
Specs:
Q6600 @ stock
3x1GB Corsair Value 667 C5
ASUS P5B
GTX 260 @ stock
Corsair 450 VX
Can anyone issue advice as to what can be done other than a new mobo?
Specs:
Q6600 @ stock
ASUS P5B
GTX 260 @ stock
Corsair 450 VX
