Cold Boot DS3 Questions
blade52x
First question: Everyday when I boot, my computer powers on for a second - then everything goes off, and then a second later it powers on again and it runs fine? Is this normal?
Second question: When I had my computer clocked to higher speeds, I'd get this long loud beep when booting, much louder than the regular post beep, and probably about 2 seconds long. Everything after that ran fine. What does this long loud beep mean?
Third question: Does dual channel not overclock as well as single channel. I seem to not be able to boot up at certian speeds with my ram in dual channel, but I will boot fine with them in single channel - normal or not?
Thanks in advance.
Thanks in advance.
Well, your lack of specifics about your system will cause me to give you very general answers, but here goes:
1) No, this is not in any way, shape, or form normal. From my limited experience with this issue, it seems to normally be caused by a failing and/or substandard power supply.
2) Perhaps it is sort of an alarm built into your BIOS alerting you that the CPU is being run out of spec? Maybe it beeps instead of displaying a message such as "FSB speed now running 230MHz.
3) That would seem normal to me, but I will admit, i'm no expert on memory/OC issues, you'd probably want to ask (cf)Eclipse about that one.
I just got a DS3 last night, flashed to F5 bios. It does the 1 second on/off, then boots too. It's not OC'ed either. I think everyone has it.
There's a large DS3 faq on XS forums under the hardware->intel section.
wow, sorry, didn't realize DS3 was a type of motherboard..... Well, sounds like #1 is a BIOS issue then, maybe there's a reason for it......
Edit: BTW, not saying anything negative about Gigabyte, but when I had a K8N PRO-SLI every BIOS update they came out for it seemed to break more than it fixed.
