I just finished a build and I'm definitely getting coil whine.
The coil whine is very noticeable at 120+ FPS and even bothersome at 60 FPS in game(csgo). If I switch to a different screen in lobby of csgo its real bad for a few seconds then settles down.
I can also hear a faint noise some times when I use the mouse scroll wheel. Which doesn't bother me, but makes me wonder if the onboard sound is picking up the coil whine more than it should be.
Setup:
i5 4590
Gigabyte z97x Sli
MSI r9 270 OC
8gb ddr3 1600
xfx 550w P1550SXXB9
mx100 256gb
Using Sennheiser HD555s
Will a discrete sound card likely fix this?
Setup:
i5 4590
Gigabyte z97x Sli
MSI r9 270 OC
8gb ddr3 1600
xfx 550w P1550SXXB9
mx100 256gb
