Coding questions about creating class instances?
JC0724
Is it possible to instantiate a class inside of a for loop and continue to make a new instance of the class as I iterate threw the for loop?
Also can you have multiply instances with the same name but if I pass in different values in the Constructor, will all of the instances exist with the same name but with different values or will it keep over writing it self?
Can I create a string and then create an instance of animal with the variable/name of the string?
Is this possible below.
class animal {
string bob;
bob animal();
1. Yes.
2. If you use the same variable, no.
3. Depends on the language. I believe that PHP, for example, can.
What you actually call the instance of your class is arbitrary. If you want to name it, you could just set a property of the class. Pseudocode using C#:
Code:
class animal{
 public string name {get; set;}
animal someAnimal = new animal();
string someName = "Midget";
someAnimal.name = someName;
You'll need to keep a reference to the previous ones you created unless you want the garbage collector to clean them up. Example typed in browser, I think it works ;)
Code:
class Animal
  public Animal(string name)
    Name = name;
  public string Name { get; private set; }
class Program
  public static void main(string[] args)
    const int animalCount = 10;
    var animals = new List<Animal>();
    for (int i = 0; i < animalCount; i++)
      animals.Add(new Animal(Guid.NewGuid().ToString());
    Console.WriteLine(String.Join(", ", animals));
