I have seen this on two PC's. One with ATI X1300Pro and one nVIDIA FX5200. Before loading k-lite codec pack the video overlay worked as expected. After installing, when I open a video file the overlay color and gamma correction settings are not being used. If I open the control panel and tweak any overlay setting then the it begins to work. So it's not that it can't work, it's just that it doesn't work quite right. Uninstalling the codec doesn't work. Codec settings don't seem to matter. If I disable overlays in the player then it just uses the display settings. Not a bad work around but since I haven't seen this exact behavior describe elsewhere I thought I would ask about it here. Has anyone else seen this, knows the cause, and how to fix it? Thanks.
