Cod4 frame rate on a 8800 GTX
nikjanet
What fps are you guys getting in Cod 4?
Myself which i think is low, all setting maxed out 4x aa 16xaf 1400x900 and all the good stuff on, im getting 90fps to 150fps but sometimes it drops to 50/60fps.I've also got the config set seta com_maxfps "250"
All my drivers/bios are up to date and have defraged .
My specs are C2D e6750 @ 2.666 temp idle 31c load 52c Stock cooler
8800 GTX core 626 mem 2000 idle 48c load 70c HR03 Cooler
2GIG Kingston
P5N E SLI motherboard
680 Hyper PSU
Any help would be great!!
Are you using the stock cooler for your Core 2? That's a mildly high load temp otherwise. Try overclocking it if you want your minimum framerate to go up.
I don't think drops to 60fps is a big deal, but maybe that's just me. It could just be swapping between the hard drive and RAM that's causing some dips.
Have also clocked the C2D to 3000mhz and made no diffrence so its back to stock speeds.
that seems to be pretty normal. my oced gtx and 3.4 quad does the same basic thing. doesnt seem to affect the 'feel" of the game at all since i have maxfps set at 90. But i imagin dropping from 130-140 to 50 would be kinda jarring.
