Cod2 + save button?
AznAnarchy99
is there one? cause its pissing me off that i get like half way through the level and die once and start off at the begining...
And is it me or does it feel like i can never heal after i start breathing hard?
Your running a dual processor like me. To fix the problem until they patch is to set single player exe to one cpu (You start your single player--CoDSP2_2.exe, then ctrl+alt+del, right click on CoDSP2_2.exe and choose "set affinity" and then only check mark either cpu 0 or cpu 1 (only check one)). Then you might have to restart the level (like I did). Hope this helps you out.
god the game is so bugged for me.. i finally kill off the tanks in the russian missions but my objectives dont update so it doesnt finish the level for me. This is both before and after i set my affinity
yea i think my health is fixed, but my objectives, never update even after i finish them
Am I the only one starting to get pissed about these games that get released with half assed or buggy support for hardware? I thought something wasn't right when I was playing COD2............
I'm honestly going to stop buying games on release days as the frustration from being the one that get's to work out the bugs is just plain frustrating.
ive been permanently banned from IW Nation for 2 years now lol..
ill try the "planets" but they've have always been no help since they are all 5 year olds
