hi
just wanted to post a log of a problem i encountered (solved thankfully), and ask a few questions
also remember that im from egypt, so my english isnt that perfect, neither is my technical knowledge
also i dunno if this is the right forum to post this in
i downloaded a program called memset a long while ago, with it i could fiddle with timing options not present in the bios
i decided to try it just today
so i ran orthos in the background to check stability and started playing around
everything was running good, till i reduced trcd: the machine rebooted by itself, i couldnt see anything on the screen, and i was hearing an infinite loop of short beeps
oh well i have to reset the cmos then, but i havent done it before...
i unplug the power cord, open the case and look at the mobo.
i quickly find the instructions printed on the board at a corner: 2-3 for normal operation, 1-2 to reset cmos
right next to it, there are 3 pins next to each other,labelled from 1 side '1' and at the other side '3'
and there is a jumper already there connecting 2-3, i take it off an connect 1-2, wait 30sec, plug the power cord and push the power button
but its not working, i mean the machine is not working, no beeps no lights no fans spinning. i try again, nothing
im stumped, i press again and again and again...nada...
i put the jumper back at 2-3...still not working
hmmmm
i unplug unnecessary components and change ram locations, but its still dead
then i unplug the power cord and plug it again...hoooooray its now working
but its still making those stupid beeps
back to where i started DAMN DAMN DAMN DAMN
then i think to myself, such a crappy old gigabyte board, cant reset the cmos
giving a closer look at the board, i find a fine print right beneath the pins 'sys fan'
*scratching my head*
wtf?
heeeeeeeeeeeeeeeeeeeey
look at that
3 small dots (u know like those u find at the back of a pcb) labelled '1' and '3' from either sides AND the word cmos under them
HOPE HOPE HOPE
obviously a jumper wouldnt work
shorting them with a screwdriver wouldnt either, they werent making contact
then i try putting my finger between 1 and 2
OH YEEEEAAAAAAH
a single beep
problem solved
now my questions:
1)wut do the short beeps mean? there was a vey short interval between each consecutive one
2)why was there a jumper on the 3-pin fan connector?
3)do all mobos have the same 'dot thing' or are they usually jumpers?
4)if the instructions say connect 2-3 for normal operation, how am i supposed to do that with the dots?
5)how were i supposed to reset the cmos? hopefully technitians dont use their fingers to do that
6)if i used a different stick of ram would it work without the need of a cmos reset? im asking that as the same thing happened 2 years ago, i sent it to a computer guy and the next day he told me the ram was corrupt and needed to be changed, so i want to know whether i was ripped off or not (obviously i was, since the replaced ram, which he didnt give me afterwards, should have worked if he put it in another computer) but i wanted to know if he did the cmos reset thing or he didnt need to
hmmmm
wtf?
look at that
HOPE HOPE HOPE
OH YEEEEAAAAAAH
a single beep
problem solved
now my questions:
