CMOS Problems
Spoonology
Basically my pc wont boot without clearing the CMOS, I've tried three new CMOS batteries but I'm still getting the same problem. Any help would be appreciated, stats are in my sig.
It'll boot, start to post, then power off, and it repeats this until I clear it, sometimes it'll do this about 3 times with out powering off but then it'll start powering off, if that makes sense.
This may be an incredibly idiotic question, but bear with me. Are you making changes to the BIOS after you reset it?
Sometimes I do, ie date and time, nothing more, but it doesn't seem to tie in to whether it'll boot without me clearing or not.
Ok this is an official plea for help :D, this is reaaallllyy annoying but I can't think what it is :/
Also it's annoying cuz I have a new hard drive, but when the pc boots I get the NTDLR is Missing error because it's trying to boot from the new empty HD . This is easily fixed in the BIOS, but of course because I have to clear the CMOS everytime I boot so the settings are set to default. Meaning I just go in one incredably annoying loop.
Maybe your ram wont run at the default voltage after a CMOS reset.
Try a slightly higher voltage and see if things improve.
Could be corrupted bios, corrupted bios hardware or something simple like a hard drive in the secondary position, set to master, while the mobo is set to cable select. Used to be an issue with ATA HD's.
I've never flashed a BIOS before, I've downloaded the newest BIOS but I haven't a floppy drive, what do I do?
As to the Ram voltage, the voltage parameters are locked in the BIOS.
They are not locked hit the + button. Also try putting in your memory timmings manually.
Tried that, I think the BIOS is corrupt because it never remembers my settings, I changed the RAM voltage and timings to what they should be (they were all way too low) but when it restarted it came up with the defaults :/
can your board be flashed with a thumb flash drive? Im pretty sure my gigabyte p35 could.. Google, how to flash your board.. Flashing the board is easy.. Also-- like posted before-- make sure you have the Volts set correct for ram-- or your board will just throwup and reboot back to stock settings-- which have to low of volts-- hence the reboot cycle... Also-- have you done a hard reset of the cmos-- where you actually remove the pin and place it to the reset postion.. Of course im reaching but i would do it all and something should hit...
I set the voltage the correct level, 1.75, but it just reboots with the default voltage which is too low.
