CMOS Checksum error - defaults loaded. What does that mean???
RavinDJ
CMOS Checksum error - defaults loaded. What does that mean??? I read on Gooogle that it could be the mobo failing. Others said it was the battery (which I tried changing and still did the same thing).
One site said that it was a failing power supply...
Another site said that it could be because an IDE cable isn't plugged in correctly.
WTF? I have a DVR system from Tempest Microsystems and the error comes up. The company is out of business and if I put the system (i.e. DVR cards and hard drive) in another system, it tells me that it's not registered... I think the software is coded to look for the MAC address of the NIC. And if it finds a different MAC on a different mobo, then it says it's not registered.
Is there a way to fix this mobo issue? Or, to imitate the MAC address on another machine?
I'm lost for words :( I spent sooo much time on this :eek: :(
is the system still working even when the error comes up? usually you can just press F1 and it will continue to boot up.. all it really means is that there was something wrong in the bios so it reset it to default..
Nope... doesn't work... It either just freezes there or it reboots a few times on its own.
I tried changing the power supply and it did work for like 1 boot, but then when I tried to test it again by rebooting, it started doing the same with the new power supply.
I'm sooo stuck on this :( :( :(
I have an old dell that does that, sometimes I can coerce it to boot and everything goes great afterwards but sometimes it will refuse to boot. Could be a bad mobo like this dell that I have.
Try changing the battery on the motherboard. It's very likely a standard button cell 3v lithium battery. Likely a 2032. Any retailer that sells batteries will have them like radio shack or wally world. Not expensive.
Also make sure the clear cmos jumper is in it's normal postion, not the clear position.
Also might be a PSU problem. I had the same thing, changed the PSU and never happened again.
i agree with everyone, only thing you need to post are cpu, mobo, psu, and ram. if ur getting checksum errors, replace battery first, next reseat ram, after that remove all ram and go through one stick at a time remembering to try all of your slots so you know it is not a slot on your mobo. if none of this works it will likely be a costly repair, either cpu or mobo (you said u already tried psu).
little trick of the pc tech trade, if your mobo does beep codes which most do, if you remove every stick of memory from the computer and boot it the beep code should match up with the one in the manual. if it does not you may have just found your problem.
