Slartibartfast
- Sep 25, 2004
Hi all, I'm having an issue with my motherboard. I got home from work yesterday, and noticed that the windows date was set back to 1/1/04 and the clock was off. Additionally, the "new hardware wizard" had popped up. My gf told me that when she turned it on earlier in the day, it had gotten some error before it got to windows, and when it got to windows the wizard popped up. I did some digging and what happened was my bios was reset to defaults (the new hardware detected by Windows was the onboard sound that was re-enabled), although the date was rather strange: it was the right month and day but the wrong time and year.
Anyways, I told her to call me at work today if it happened again, which it did. From what she said, the bios was giving an error that said CMOS checksum Error, press F1 to continue, or DEL to enter setup. I told her to just press F1 (wasn't about to try to talk her through the bios
), and apparently the same thing happened because the new hardware wizard popped-up again.
So what's happening is, when the PC is powered down the bios loses it's settings, but once you get past that original error, you can reset the PC and it will keep the bios settings, which leads me to believe it's an issue with the battery (which sucks, the mobo is less than a year old) because it only loses the settings when it's completely powered-down. The mobo is a Chaintech S1689 (budget board), I'm not sure of the bios but I'm pretty certain I flashed it to the latest.
Bascially I'm wondering if this sounds like a battery issue to anybody else. I was figuring on resetting the cmos when I get home, but I've never had a battery die on me before (even on 8+ year old comps). Do you think I could get a replacement at like a radio shack or would I have to go online?
