cmos checksum bad... ?
Xenozx
cmos checksum bad
i just got this error message from my computer. mainly i would like to know what it means.
I will tell you the whole story below though...
I moved my computer from the floor to a table. Anyway from there i connected everything and powered on. It booted up and gave me the message CMOS check sum bad. Well i kinda know what the cmos is. its what saves all your bios info and date/time etc? anyway i proceeded to enter bios to reconfigure everything. I set everything as it was before. I rebooted and boom. no more computer. right after i saved my bios settings and exited my monitor just went blank like it was getting no signal. I waited a bit then powered down all teh way waited 10 seconds and powered back on. monitor would detect something hten it would go blank again. so i followed motherboards instructions and cleared CMOS. (took battery out/switched jumper/put battery back) anyway it just posted and before i do anything i figure i would post this.
It gave me the following:
cmos checksum is bad
date & time is not set
press F1 to enter setup
anyway if my check sum is bad what should i do to fix it? what exactly does this mean?
i have an asus a8v
im using beta bios 1005.21
Your bios isn't configured correctly.
Try to load optimised/performance defaults from the bios, should work.
yea looks like that got me back up and running, i was able to get back to my overclocked settings too. Its just strange it would do that out of the blue.
