Cmd
JFav
When I go to start, run, then type in cmd for the 32-bit command prompt (on windows xp home edition) the prompt flashes on the screen then disapears.
So then I open the 16-bit command prompt and it works however, when I use simple commands like change directory(cd target folder) it doesn't work. Then when I want to close out, it doesn't do it automatically and comes up with a non-responding window asking for me to end the task.
Any Ideas?
Typing exit rather than closing with the x will get rid of the not responding. (should anyway)
