Has anyone out there run into this problem:
You run a program from within an If statement and try to evaluate the return code only to find it is set to 0 as in the following example:
IF exists "\\%FileServer%\sys\users\%username%\Outlook\%file%" (
<...do stuff...>
IFMEMEBER "%UserDomain%\Circular230" <---For the user running the test this finds a match and displays a message to that effect and under normal circumstances sets ERRORLEVEL = 1
echo %ERRORLEVEL% <---This should output 1 but it outputs 0 instead.
pause
IF [%ERRORLEVEL%] == [1] (
%systemroot%\system32\cscript.exe <script> //Nologo
Goto:EOF
To fix it I did the following:
Xcopy ...
Goto SETREG
<..other stuff..>
:SETREG
echo %ERRORLEVEL% <---This now outputs 1
pause
Goto:EOF
It seems like the code for handling IF doesn't handle return codes or am I missing something? I normally do things in VBScript but for quick and dirty solutions I use batch. Shame on me?
The script now does what it's supposed to do but I just wanted an explanation for this behavior or a tip on how to properly handle return codes when inside an IF statement.
Thanks in advance.
<...do stuff...>
pause
Goto:EOF
Xcopy ...
Goto SETREG
<..other stuff..>
:SETREG
pause
Goto:EOF
Thanks in advance.
