CMCenturion 5 Cable Management Pics?
Hey guys -
I managed to score a free Centurion 5 case and going to use it for a build. This particular case doesn't have mobo plate holes for stealthing the cables. I'd like to see some pictures of examples for how to best do some cable management in this case if you'd all be so kind.
- MG
You should do somethin about that little mess right above your cooler. Other than that looks good.
Here is my unmodded Centurion 534 (the only difference with the Centurion 5 is that the HD rack is perpendicular).
P.S. if someone could tell me how to resize images I would really appreciate it.
Resizing pics in Paint is eassssssssy.
open paint
click edit -> paste
Click image -> resize / skew
enter % to resize. (enter same number for vertical/horizontal - no change = 100%)
easssssy
open paint
click edit -> paste
easssssy
Yeah, but that requires uploading the picture again :mad:
I was wondering if there was a way to do it in the forum itself. On other forums, I can resize the image in my post.
...so the problem is?
