CM690 and the Second Front Fan...
connec
... the Unsolved Mystery.
Basically, the box shows the case with two blue LED fans on the front, however there is no 'out of the box' way to install a second fan above the lower one. Is there a commercial mod avilable (such as the side-panel with a window) or is this something I'd have to fix myself?
Any help appreciated.
Seen it done with zap straps... :D Check around the forum for posts... I think there was one about this case asking about 3 120mm intake fans.
You'll have to put it in yourself. A 120mm fan takes up three 5.25" bays. It's really quite easy, all you need are some zip ties or elastics, and you can just thread them through some holes to mount the fan.
scythe KAMA bay would work for you? (I'm not sure if thats the correct name...) It is a little attachment for the 5.25" drive bays that lets you install a 120MM fan in.
