CM Storm Scout - PSU seating
Kirbstomp
Looking for ideas on where I could find 4 very small and thin adhesive pads, either rubber or foam, to help seat the power supply in my CM Storm Scout. Currently, the case just has raised metal bumps that I would prefer not to have the PSU sit on. Any alternative ideas are also welcome on how best to cushion the PSU in this case. You can see these raised metal bumps outside of the fan filter here.
Another thing I need help with is what to do about the blowhole fan on this case. It has no filter on it from keeping dust from settling while the computer is off. It is a 140mm fan though, so I would either have to make a custom filter out of something, or just use a 120mm fan filter and only have it cover part of the blowhole.
Also, I am planning on replacing the plastic feet with either the aluminum rubber feet from my ATCS 201-B or using some rubber feet I picked up from FrozenCPU.com. Not sure when I will get the actual build, still awaiting a few parts.
