CM Stacker Bay Cover Issues
DangerIsGo
Does anyone have the TC01 or the 810 stacker and have a problem with the bay cover filters staying in place? Like if I touch mine at all, they can easily be pushed in and it looks ugly. Anyone have any suggestions? Solutions?
you could always put little pads, spacers, rubber feet... there's lots of things you can put in there
Yeah, with the original stacker, once you pop open a bezel, it tends to "STAY" popped out. I just bend mine a little before reinserting them. No biggie. As for cleaning, just take a vac to the front of the vent and spray some canned air from inside the case. :D
