CM stacker 830 sleeving job
Cambo
So i decided to move my computer from my old ATC-101 case to my Stacker 830. I was getting really high temps and i did not like how loud the fans were. Here was my old setup, very cramped, even for a large case.
After moving all sorts of dust and build up from my components, i started sleeving every single cable that i was using in my case. I did not want to see any colored wire.
I bought the following at fry's. It's a decent price at 7 dollars for 20ft of the 1/8" inch sleeving, which was mostly what i used. I was thinking of getting the MURDERMOD sleeving kit, but that was a bit steep. I did not want to pay 35 dollars for a sleeving kit. I ended up buying 3 packs of sleeving for 21, and 2 long tubes of heat shrink for 3 bucks. I also did not want to wait for them to ship it out, so i just went over to frys.
I started with the fans. It was soo easy, just popping off the wire connectors, sliding the sleeve and two heat shrinks and reattaching. It really looks nice.
Then i did the motherboard headers from the case along with the USB headers and the Front panel audio.
I am particularly fond of the CPU cooler fan cable. It now has this neat little arch, looks very clean IMO.
Then i did the SATA cables and then connected everything up. I used 1/4" sleeving for the SATA cables. This fit perfectly, as there was no way i could get it to fit the 1/8" sleeving.
I don't know about you guys, but the CM stacker 830 does not leave much room behind the motherboard tray to hide cables. I had to force the side panel on and it's bulging. I may cut some holes in the motherboard tray to allow wires to pass through like alot of other cases have. I don't remove the tray much, so it won't be an issue.
Next up is the 24pin ATX connector. I tried for a half an hour this weekend to remove the pins so that i can sleeve the wires individually, but the two staple method was not working. Does anyone have a video or a diagram of how the connectors are secured, that would be great. I hate looking at the colored wires on the atx, especially when everything else is sleeved. This took up about 6 hours of work. Please comment.
I will update when i figure out how to get those pins out. I will also be painting the plastic shroud on my 8800 ultra. I'm still working on what design i want to put on there.
It looks really nice. What tool do you use to pop off the connectors for the pins. Can you explain how to take them off and put them back on right?
for the Fan pins, i just stuck a sharp object into the side opening and pulled out the wire.
Refer to the following link for detailed instructions. This was my first time sleeving, and it was a breeze. I still don't know how to remove the 24 pin atx wires yet, but eventually it will get done.
http://www.xtremesystems.org/forums/showthread.php?t=202639
The board is an EVGA 650i ultra. The Video card is blocking the badge. The Video card itself is an 8800 Ultra. I bought it from craigslist for a steal last year. I think it's a testing model or something. Not sure, but it works great. I will be painting the shroud soon to give it a little bit of a custom look.
So i've started the process of trying to sleeve the 24 pin atx connector. I have a corsair tx750 and i could not get the wires to detatch from the connector. I figured it would be best to sleeve an extension, especially since notbody would see the difference.
I started out with this:
I used the two staple method to remove the wires from the connectors. It took a very long time, but i think it was worth it. I watched two whole movies while doing this and i ended up with this:
Once installed, it looked quite nice. I need to tighten up the wires a bit, but nevertheless, i think it looks decent. not bad for 8 bucks for the extender and 8 dollars worth of heat shrink and sleeving.
Nicely done sir. I ordered a sleeving kit that will be here Tuesday for my computer. I decided to do it after viewing the same guide that you linked to. I hope mine turns out as nicely as yours. Good job.
If you can, i suggest putting some glue on the inside of the heat shrink before shrinking it, or using the type that already has adhesive on the inside. Mine were slipping out here and there, so i'd have to re-shrink the area.
Focus... Focus! FOCUS!!! :D Seriously, nice mods, and a little camera knowledge will allow you to show it off better. Either set your camera for macro or closeup pics manually, or put your subject matter down (ie on the table) and photograph it... Then we can see what a nice job you did.
You can also buy glue-backed heat shrink, as long as you're sure you aren't going to try to change anything later. It'd be a bitch to get back off.
nicely done. this is on my list of things to do while my A900 is torn down for rebuild. I was going to sleeve the 24 pin, but decided I'd rather break an extension if something went wrong as well.
sorry, i wasn't in th ebest mood for taking the best pics, i was just trying to keep a log. sorry if they are out of focus, it's just a simple point and shoot. I'll keeep it in mind for better pics in the future.
nice job Ive been back and forth with doing this also . But I have this reoccurring nitmare that I switch wires and fry my comp.
Nice job! Reminds me that I need to start going for some nice quality sleeving instead of the cheap crap, lol.
