If you get one watch it when building with the thing. It is a box of swords inside and out.
It also weighs so much that it can probably cut off important body parts if not handled carefully. Probably why it comes with wheels, as picking it up to move it can remove your fingers. Should come with box of bandaids. The side panels do not fit well (too loose) and are hard as hell to put on ( wait till you try it before before you scoff). The top fan rattles unless you tape or wedge it with something. Otherwise, it is a nice case. And will probably hold about anything you want to put in it, although I had to remove one of the 4 120mm fans from the door to clear the CPU heatsink (TR120 EX).
fxtWell good thing about the wheels, unfortunately there's a 2 year old running around here so I need to throw the kid out so that I can buy this case![]()
