M76
- Jun 12, 2012
I'm hopelessly undecided between these two fans. Help me Obi-Wan Kenobi, you're my only hope.
Speed 1500 RPM+-10%
Air Flow 82.6 CFM
Air Pressure 1.273 mm-H2O
Noise 26.5dBA
Fan Speed 800-2000 RPM (PWM) ± 10%; w/ silent adapter: 1600/1200 RPM (fixed)
Air Flow 95 CFM ± 10%
Air Pressure 2.72 mmH2O ± 10%
Noise Level 19 dBA (1200 RPM with included silent mode adapter)
28 dBA (1600 RPM with included silent mode adapter)
12-36 dBA (PWM)
The dedign certainly is in favour of the Shark, but the pressure of the CM is much more. Altough they don'T indicate how that changes if I want reasonable noise levels, as the fan is unbearably loud on max rpm. I'm aiming for 19 dB.
I intend to use them as case fans to push / pull air to / from the radiator of the CPU cooler.
Speed 1500 RPM+-10%
Air Flow 82.6 CFM
Noise 26.5dBA
12-36 dBA (PWM)
