CM Centurion mOD
emir
Not so assertive but wanna show our work 2 u
..:: WATCH ::..​
wackarific my friend. But, the dude who is running the camera needs to learn some new skillz yo.
- JT
Is that a 140mm fan at teh back? It doesn't seem to fit quite right is all. Also I'm considering getting that fan too (well three actualy; two for the front and one for the back) how are they compared to 120mm fans?
Mike
@Mike_Check ;
Yeah it's 140mm,it doesnt fit at all,but no problem about it,i manage to fit it tightly :)
The fan is awesome,no noise and good cooling but not so perfect ;)
No need to consider,it's so cool :cool:
so it's worth getting then or the standard 120mm are fine? I think 140mm JUST fits in the 5.25" bays and seeing as how I've removed the 3.5" bays anything will just about fit.
So are they worth it?
Mike
