CM ATC-110 Side Panel
penguin
Hey guys,
Does anybody know if the side panels from ATC-110s are compatible with any other CoolerMaster cases out there? I just got my hands on an ATC-110, but I really want the factory side window. Any suggestions? (I would cut it by hand, but if I make any mistake, it's not like I can just get a new side panel, ya know?)
IIRC it uses the same side panel as the praetorian, correct me anyone if im wrong
penguin said:
Hey guys,
I believe they're all the same. If the internals are the same the externals are.
Most, if not all, of the Praetorians, ATC-110 and Wavemasters have the same chassis, they're outsides differ.
Compare the dimensions of your case to a Praetorian and if it's about the same then the side panel should work.
The 110 has very different chassis to the other coolermaster cases (Part of the reason it was discontinued). Those who are thinking it was using the same chassis as other coolermasters are thinking of the 111 not the 110 they are very different cases inside despite the identical looks externally.
I'm pretty certain any of the other case panels won't fit as the 110 has two thumbscrews for the side panels and the others have 3. I beleive cm did a side panel for the 110 but it was never released to my knowledge.
Cooler Master did sell the ATC-110 with side window panel and window panel separately. But the quantity sold was always very low and only a few stores back then had them.
Ok, thanks for the info.
I actually might have found a window side panel for it on another forum :D
