CM 840 & watercooling?
knightsilver
I guess I dont know where to look for watercooling on [H].
Would the CM 840 work well with watercooling?
thanks.
Yes it works very well, at the top you can put up to a 3x120 radiator. As well as at the bottom I believe. I suggest you go on youtube and look at some of the videos of the case. Or check the worklog section as there is a really nice thread on a CM ATC 840.
