CM-690 Front Panel installation
gunner46
Hi All
Just received my CM-690. I have a problem re-installing the Front Panel.
Is there some trick to doing this, when I push on the top left, the bottom left pops loose. When I push on bottom left, top left pops loose.
Am I doing something wrong ?
I like the case very much, but this is getting very annoying.
Can anybody help please?
if you still cant get it, some of these cases have loose front panels from the get-go. the plastic knob-thingy that holds it in place are probably permanently squished in, therefore cant fully secure the panel.
happened to my first time (both of the top corners couldnt be held in), then i returned it, and now theres only one bad clip on the 2nd case. i just pushed it in and stuffed it with a metal rod so the knob would remain open..
Make sure the on/off and reset switch aren't getting in the way
If you leave the side panel off it makes life at little more simple when lining the front up
