Just a drop of 2-3 degrees in push-pull AFAIK.
You might get better drop if using push-push method,but it's still in debate.
My CPU is at 32C - 34c no OC, and at idle using one fan as a push into the HS.
I have a 200mm about an 1-1/2" away just above the HS. then is a second right
next to it, but not directly over the HS, more towards the front of the case.
The top back case fan lines up with the heatsink fairly well, but is about
3" away, its 120mm.
Thus my question, if it would be worth it or not?
with the 200mm fan there i wouldn't bother with a push pull config since its possible you may hurt the cooling performance due to the difference in fan speeds even 3" away the 200mm is still drawing heat directly away from the heatsink.
